As of today, September 26th, bullet icons do not appear beside newly created bullets 4.3.2609252236 [beta, chrome-153, mac], 4.3.2609252236-beta [desktop, mac] and 4.3.2609252236-beta iOS. It doesn’t matter which platform I create a new bullet on, the bullet icon doesn’t appear on any of these three platforms. To clarify further, if I create a bullet on one of these platforms and then view the same bullet on another platform, the bullet icon still does not appear. This has been reported to the WF team through “Report a problem”
Ksenia responded with a solution which worked for me, but it is puzzling as I don’t use paragraph or headings formats. Here is the solution "It sounds like those nodes might be in paragraph format – no bullet would show unless you hover over it. Pressing Enter after a heading or paragraph creates another paragraph, which hides the bullet dot unless you hover over the item.
There are multiple ways to switch back to a bullet format:
select a node or multiple nodes you’d like to switch using Cmd + click, then select desired node’s type from the pop-up menu (and you can learn hotkeys from that menu as well)
click on the node’s menu (next to the bullet) > Turn into… > select desired style
use inline command /Bullets or any other desired style "
Yes, if you inadvertently created a paragraph just through a typo then every mode you created below it would also be a paragraph. but the solution would simply be to change them all back to bullets and then if this theory is correct it wouldn’t happen anymore. I am not seeing this in 4.3.2609252236 [cap, android-17]
