FIXED: Panes BUG in beta (serious enough to revert to production): Basic typing all fouled up
In 4.3.2609081459-beta [desktop, linx] and 4.3.2609081459 [beta, ff, linx], with more than one pane open: creating nodes, tabbing nodes, typing into newly created nodes is sporadic or broken.
Trying a system update and reboot in case it’s just my system. Will report back.
On system update and reboot: bugs still exist. And can’t expand or collapse nodes.
Workarounds are to not use panes or revert to production.
Not seeing on 4.3.2609081459 [beta, edge, win]
Good to know: redoubling my testing locally to make sure it’s not just my setup. Thanks, @jodmarch
@michael actually I am now seeing it, also severe. It looks like it may be a rendering issue, not a data corruption issue, but in any case I agree it makes this beta unusable.
@jodmarch Yep; severity level: “yikes”
Upon further testing:
  • Working in production on this same machine: 4.3.2609071723 [ff, linx]
  • All good on 4.3.2609051833-beta [desktop, linx] → another laptop, same OS, relatively similar system updates
  • Failed on 4.3.2609081459 [beta, chrome-152, linx], 4.3.2609081743 [beta, chrome-152, linx], and 4.3.2609081743 [beta, ff, linx]
Update: fixed, maybe?
On 4.3.2609071723 [ff, linx] and 4.3.2609082011-beta [desktop, linx], I was still experiencing these bugs.
Then I refreshed them both (ctrl-R). ← I had tried this earlier today.
And now they are working again: typing, indenting, expand/collapse seem to be “operating nominally.”
@jodmarch If you can test, can you confirm beta is working after a refresh?
On VERY brief test, it does NOT appear to be fixed in 4.3.2609081844 [beta, edge, win]
It seems that I have encountered the same issue.
Same here. I am experiencing significant lag when a pane is open, specifically when creating a new bullet, completing it, deleting it, moving it between panels, or expanding it. However, typing text works perfectly fine without any latency.
4.3.2609081844 [beta, chrome-152, win]
This should be fixed on Beta and the Beta apps soon. Thanks for reporting!
FIXED in 4.3.2609091429 beta
Working for me, thank you: 4.3.2609091843-beta [desktop, linx]
@jodmarch Is it repaired on your end?
Yes, apparently fixed. Thanks for the followup, @bobmhughes
Cool, I’ve marked it on the thread as fixed.
There’s also a fixed tag available now.
