Global Serach as default on mobile
I mostly use global serach on mobile so i would prefer if the search button in the bottom right would open that instead of normal serach.
Press Home before the hourglass?
Context search is important as well so maybe ask for an option to define all searches as global?
Thats also two clicks to bring up global search. I use global search way more often then context search, so for me the two buttons should be swapped so it is only one click away.
I get it. Just trying to focus the request.
