Keyboard: move cursor to bottom node?
If I want to use the keyboard to move my cursor to the top item on the screen, I can press “Alt-Up then Alt-Down”. It seems like a hack, but it works. If I want to move my cursor to the bottom item in the current view, is there a way? So far I’ve only found how to do it with the mouse.
In Dynalist, I used to have these actions bound to Alt-< and Alt-> respectively.
Not perfect, but Ctrl+End moves down a screen and a bit at a time. So depending on the length of the page…
