Is there a way to list the shortcuts I created?
Nope
Would be a huge timesaver to pull up a list of all the shortcuts.
+1
Is that a comfort thing or something specific that saves a huge amount of time? No snark, just wolndering,
Since I created a lot of shortcuts, for me it would have been a huge time saver.
Instead, I had to make a record of them all manually.
Yeah, I thought of that originally, keeping a list. Then I decided if I entered what I thought would be a shortcut for a node and wasn’t right I could just recreate it then. Quicker than a list check and no damage done. Shortcuts I forget make no difference so juice not worth the squeeze. My view anyway. I am specific with shortcuts I use for AHK though.
I agree that a hotkey to list all assigned shortcuts would be helpful. Until they add this feature, I created a Navigation node. It’s not perfect because I have to remember to add each new shortcut to the Navigation node but once I created my list of frequently used shortcuts, I didn’t need to add more very often.
