MCP Server for integrating Workflowy with AI tools, respecting indentation and formatting
I have built an MCP server for Workflowy that respects indentation, search, retrieval etc.
You can download it here: GitHub - dromologue/workflowyMCP: An MCP server that uses Workflowy and Claude to manage Tasks & Information in Workflowy and create a Second Brain · GitHub
I use it with Claude but it will work with any AI tool that implements MCP.
updated to include concept mapping.
Hi dromologue, what is the use of it with respect to the integrated ai tool provided in workflowy?
In my workflow it is helpful to get it to insert research directly into Workflowy. Also using the productivity skill in Claude it can use Workflowy as the context to manage tasks etc as well as integrate with cowork.
This looks great. I just used co-work to build a travel itinerary and it created a notion page in an appropriate place in my workspace without asking. I’m curious what your experience is with something along these lines.
When you mention “the productivity skill in Claude” do you mean a specific named productivity skill? Or do you mean “whatever productivity skill one happens to prefer”. I’m not aware of a Claude productivity skill other than those that people put together themselves.
