Mobile Multi-Select
Long-requested, you can now select multiple nodes on Mobile. Long-press a node, select several, then use the drag-handle to move them. Use the bottom toolbar to change item type (todos, bullets, quotes, etc.), duplicate, move or mirror.
Any secret to selecting a weblink node (not jumping to the page),
Love this thank you! And not sure when the little drag lines were added on mobile too, seems much easier to move bullets around on iOS in general lately. Thanks!
I usually click on some space to the right of the last character of the URL.
Looks like you have to turn on “workflowy Labs” under settings | features to get this to work. Probably let people know this unless that’s a bug. Thanks for including this feature though, it’s one of the main reasons I stay tied to my laptop instead of mobile when using workflowy
Either I am pressing better or upgrading to IOS26 and the most recent WF upgrade have improved the process. Yeah.
Ahh, thank you!! I was unable to get it working, turning on “workflowy labs” did the trick
