Mobile quick add: work offline
Thank you for a great product!
Offline mode has been supported by Workflowy for a long time, first in the web app,and later extended to the Android app. This feature has always worked perfectly.
However, it doesn’t work with the quick add feature that was later introduced on Android. When the connection is poor, it prompts that there is no network access, preventing from submitting a quick add.
This is despite the fact that I can still manually add items to theWorkflowy inbox at that moment.
It would be perfect if the quick add feature could also share Workflowy’s offline functionality.
