Patch Notes - Sep 18, 2025
  • Press Ctrl (Option on Mac) and click a date tag to search for that date in the current node and descendants.
  • New “/Mirror To Child” command, by analogy with “/Move To Child”
  • Searching for your own mention now shows correct results in private spaces as well
  • Duplicating expanded nodes no longer leaves the duplicate in a weird half-expanded state
  • Pasting [t] and similar is no longer treated as a markdown todo, the pattern is narrowed down to [ xX-]
  • Improved cursor positioning on Android, so it doesn’t get hidden behind the header when the keyboard is opened (let us know if it still does for you)
  • Sharing a .txt file to Workflowy on Android is now recognized as text share and the file contents are automatically added to the text area
  • Using numbers as shortcuts no longer provokes sync errors in some situations
  • Typing e.g. “5.10.2025” is now recognized correctly with a custom date format like “DD.MM.YYYY”
  • Fixed Japanese character selector highlighting when using keyboard on iPad Workflowy
Ctrl+Date is very nice, thanks.
I’m loving the new Alt-T feature! It perfectly solves the “Where is Today and how do I navigate to it quickly?” issue. Thank you!
Apologies for the confusion, but how does CTRL+Date work?
@calsi
Hover over a WF date and press Ctrl+LeftClick and a search for that date in that context will occur. Just like left clicking on a tag,
Sorry should have been clearer in the original post.
Many thanks! :folded_hands: Very much appreciate the tips. :+1:
@calsi
