Much requested and finally here, you can now open Panes in Workflowy.
Panes keep multiple parts of your Workflowy outline open side by side in the same window.
Keep your Today node open while you work, reference notes while drafting a document, or move nodes between parts of your outline without losing your place.
Each pane is a view of an existing node, not a duplicate. Any edits you make in a pane update the original everywhere it appears.
To create a new pane, press the ‘New pane’ button in the header. To open a specific node, hold Alt (Option on Mac) and click its bullet, choose Open in Pane from the node menu, or type /open in pane.
Note: Panes are available in desktop browsers and the Workflowy desktop apps. No mobile support (yet).
For more, including keyboards shortcuts, visit the Panes help doc.
