Selected bullets didn't turn into checkbox
Desktop app: 4.3.2508061542 [macos]
Operating system: MacOS Sequoia 15.6
  • select bullets
  • using keyboard shortcut try switch to checkbox
  • but switched only one, where cursor is
PS. Can’t prove it, but I believe earlier it worked!
I can confirm on beta web and beta Linux.
It also fails when selecting several then using the “Turn into” option off of the left-side “…” node menu.
It works fine when you use the pop-up menu that appears after selecting several nodes.
