i tend to have to use the euro symbol (€) a lot and on mac this is option+shift+2,
veeeery close to one of the pane opening shortcuts: control+shift+2, which i by accident seem to press 75% of the time i need the euro symbol… **facepalm**
help!
help!
You can null out or change the Ctrl + Shift + 2 hotkey using the Command Palette hotkey process. That would eliminate the issue. Of knowing a hotkey in the command palette. Example of nulling a hotkey in the command palette.
To disable particular hotkeys for some commands, use the hotkey configuration feature to assign different hotkeys to these commands.
customize_hotkeys command in Command Palette | Workflowy Help
