I have two Panes open. When I select the drop down for Expand or Collapse all, nothing happens. it doesn’t expand or collapse either of the nodes on either pane.
Now it’s expanding the panel on the left, even though I’m trying to expand the panel on the right.
Selecting from the drop down does not work for me either.
Try using the Ctrl+DownArrow and Ctrl+UpArrow hotkeys. They work for me.
I’m on a Mac, I tried Ctrl and Command but both of them didn’t collapse the lists when I have two panes open - did it work for you?
Windows, and Ctrl + Up/Down collapse/expand.
Hey @candlesyp could you share what version you’re trying this on (web/desktop) and version (standard/beta). Each pane should have its own expand/collapse buttons, when you try these, the nodes for that side don’t expand right?
