Use Ctrl + Alt + Up/Down on PC, or Option + Cmd + Up/Down on Mac. Handy for navigating large expanded nodes or board columns.
FYI: In Linux (Gnome), Ctrl-Alt-Down and Ctrl-Alt-Up are mapped to “switch to workplace down” and “switch to workplace up” respectively. These are not accessible from the place you normally set shortcuts: Settings/Keyboard/View and Customize Shortcuts.
To get this new WorkFlowy navigation working, you can use dconf-editor. Replace the default with [] for each.
Woah, thank you so much. This was a long time request of mine.
Appreciate this!
Improvement:
When in a long list of child items, can we also have Ctrl+Alt+Left to move to the next immediate parent?
OR
or Ctrl+Alt+Right to move to next immediate deeper nested point?
Will add some more flowy ![]()
